Who knows how to use the proprety "HyperTrendCtl2.CurrentSettings" ?
Hi all.
I need to save to a file the configuration of a HyperTrendCtl2 ActiveX Control.
I have seen on the help of the control that exist a proprety to get and set the configuration of the ActiveX Control HyperTrendCtl2.
I have tried to use in LabView 7.0 this proprety with a simple VI which gets and sets the proprety to the same HyperTrendCtl2.
I run continuosly the VI and after a while LabView Chash.
Who has more information about the use of this ActiveX.
The help of HyperTrend is so poor of information.
(2,706 Views)
Silvano,
I am able to reproduce the crash here. What you are doing should work. I have reported the bug.
I assume that what you are trying to do is to set up the hypertrend and then save the state so that it can be restored. If that is the case, then the work around is to read all the individual properties.
Carl L
(2,706 Views)
