Hi Roland.
I know that in BridgeView 2.1 and LVDSC 6/7 I can use Write Tag.vi. It is working, when I write a memory TAG with generate event = true I see on the Alarm & Event viewer a new green row (An event). But with BridgeView 2.1 I can do that with input TAG and without using write TAG.vi. Simply I configure an input TAG to Log & Print Events, No alarm enabled but set alarm message. I don't have to write G code for this. When the input will be active the engine generate an event on the Alarm & Event viewer.
I use this functionality for log operator action. For example an operator push a button on the console (wired button), the TAG engine generate an event so I can see on event list the sequence of operator's actions.
The main question is "W
ho knows where are the alarm messages ?".
In the TCE I on tab Alarms there is the field "Alarm Message".
The help said "Type the text to display and log when the tag is in alarm".
With LVDSC7 I can't see this message In "Alarm & Event Viewer".
By Roland, thanks for your quick answer.
