Why I can't deploy the system definition file to a RT system
I am using NI VeriStand 2011  and try to deploy the system definition file to a PCI RT system, but the deployment failed with this error message:
Error code:61060
Details:
Error 61060 occurred at Project Window.lvlib : Project Window.vi >> Project Window.lvlib : Command Loop.vi >> NI_VS Workspace ExecutionAPI.lvlib : NI VeriStand - Connect to System.vi
This error code is undefined. Undefined errors might occur for a number of reasons. For example, no one has provided a description for the code, or you might have wired a number that is not an error code to the error code input.
Additionally, undefined error codes might occur because the error relates to a third-party object, such as the operating system or ActiveX. For these third-party errors, you might be able to obtain a description of the error by searching the Web for the error code (61060) or for its hexadecimal representation (0x0000EE84).
What causes this error, and how can I solve the problem?
I precise that (according to previous forum post/support documents) the number of the packets I read from the DMA Write match the iteration number.
I have attached the Veristand FPGA project including bitfile and config file
Regards
(3,580 Views)
Thanks you for posting on National Instruments Forum.
The number of the packets you read from the DMA Write match the iteration number.
But in your Custom Personality FPGA the number of packet is 7 and the number of iteration is 11.
Let me know when you test this solution.
Brice S.
National Instruments France
(3,557 Views)
Hello!
Thanks for your proposition.
The solution seems to work
Regards
(3,539 Views)
