Why I have to set "Wait Until Completion" to F in order to make my vi work properly work when I pass param to system exec.vi
I got an error, please see the attachment. The runme.bat is "mercierxmodem COM11 "xmodem" c:\MercierPromptsEN.bin", its path is c:\runme.bat. I still can't make it work. 😞
Message 11 of 15
(810 Views)
Where else is Com11 open???
Bill
CLD
(Mid-Level minion.)
Message 12 of 15
(803 Views)
Now I added another visa close before run this batch file, still doesn't work. The result I got is running forever till I close the cmd.exe window. But if I set Wait until Completion to F, I got nothing. Please see the attchment. Thanks!!!
Message 13 of 15
(795 Views)
Well now the problem appears to be different.  So you're sending the file via xmodem... but is the client ready to receive it?
Did you add the VISA close there for troubleshooting purposes?  Normally, I'd trace the issue back to where it should've been closed and then close it there.
And I'm sure you know this, but setting the flag to false merely makes the VI ignore the fact that the command line is hung, and it's not really working properly?
Is this the only way to do it?  Instead of calling it from the command line, is there a dll it hooks into that you can call directly?
Bill
CLD
(Mid-Level minion.)
Message 14 of 15
(773 Views)
Taking a A long shot here.
Try removing the working directory input and just use command line input ONLY.
Message 15 of 15
(764 Views)
