Why I keep getting errors when I try to create my labview application as Active Server in my VB code? (Activex component can't create object)
Error happens at the statement "CreateObject("myapp.Application")
(2,803 Views)
I am not quite clear about your question but my best guess is that you have not register your LV ActiveX Object. Try to run that LV object once to register.
tc phan
(2,803 Views)
Thank you very much! That is what needs to be done!
(2,803 Views)
