Why MATLAB® Language Syntax Return Error 1048?
Why Does My Script Written in The MathWorks, Inc. MATLAB® Language Syntax Return Error 1048?
x = (0:0.1:10)';
y = sin(2*x)./exp(x/5);
trnData = [x y];
numMFs = 5;
mfType = 'gbellmf';
epoch_n = 20;
in_fis = genfis1(trnData,numMFs,mfType);
out_fis = anfis(trnData,in_fis,20);
aa = evalfis([x x1],out_fis);
http://www.mathworks.com/help/fuzzy/anfis.html
(4,163 Views)
now, it's fine
but i also have  this probleme
x1 = (0:0.1:20)';
y = sin(2*x1)./exp(x1/5);
trnData = [x1 y];
numMFs = 5;
mfType = 'gbellmf';
epoch_n = 20;
aa = evalfis(x1 ,out_fis);
(4,143 Views)
Hi mikhael,
why do you mix MATLAB and LabVIEW in this wierd order?
Why not use basic LabVIEW functions instead?
(4,123 Views)
What do you get if you define the output as a 2D array?
(Or transpose the vector. Remember that matlab has a distinction between row and column vectors and LabVIEW does not). If you create a 2D array, it can be 1xN or Nx1 and you get all elements either way.)
(4,107 Views)
