Why NI cDAQ-9178 is not listed in the simulated DAQmx device in MAX?
Hi all,
I want to create a simulated device for cDAQ-9178. But in MAX, I couldn't find this. It lists only NI cDAQ-9172. I have NI-DAQmx 8.9.5 version.
Raja
LV 2009
(3,243 Views)
Do you see it listed in the supported devices in the 8.9.5 readme? What about in the current version (9.0.2) readme?
(3,242 Views)
Accepted by topic author RajGru
Hello Dennis,
NI cDAQ-9178 is listed under DAQmx 9.0.2 supported device.
Raja
(3,229 Views)
You could mark my answer as the solution instead of your thank you.
(3,213 Views)
