Why TEDS Microphone(GRAS 46BD_FV) Calibrated Sensitivity get wrong Value?
Accepted by topic author Sam.Huang
If you want to measure the sensitivity of the Reference Mic, the method is the same just change the task Type to AI-Voltage and insert the external amplifier, everything else can remain the same.
Now, the measurement you get is in Vrms, if your test stimulus is 94dB SPL 1kHz tone, then the Vrms directly translates to V/Pascal
Santhosh
Soliton Technologies
Message 11 of 12
(488 Views)
Thanks,set up task type "AI_Voltage" measured Microphone sensitivity.
Message 12 of 12
(478 Views)
