Why These two while-loop can not run parallelly ?
I place two same while-loop in the block diagram and then use highligt and single step executing function to observe their parallel running.
But I discover that this two loop run alternatively, and can not run simultaneously.
Anyone can help me to understand this ?
My software enviorment:
OS: Windows XP SP3
Labview: 2011 Student Editions
CPU:    intel P8400
(3,675 Views)
Can you repost your VI in some older LabVIEW versions, So everyone can have a look.
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
(3,664 Views)
thank you for responce
(3,661 Views)
Hi shiiuen,
those two loops run in parallel...
But you explicitly "use highligt and single step executing function"! What do you expect with single step execution? And highlighting will always show step-by-step execution, so what do you expect here?
(3,639 Views)
Accepted by topic author shiiuen
Thanks for reply
I post a video to illustrate my question.
While I press a highligh and run, I find that these two loops do not start at the same time.
While a loop run, the border of other one became dark.
It seems that while loop 1 run one iteration, the loop2 keep waiting. and then the loop2 run one iteration while loop1 keep waiting.
I do not know why that happens
Sincerely
(3,629 Views)
As GerdW said, selecting highlight and/or single step shows one step at a time. It is a debugging environment.
Turn off highlight and the loops will run in parallel during runtime.
_____________________________
- Cheers, Ed
(3,614 Views)
Oh, I see, that explains the matter.
Thank you very much.
(3,602 Views)
