Why VISA not work after building the exe application ?
 I am trying to read the pressure value from edwards TIC controller and for this I used the VISA read function in VI and it read the value from TIC controller but after building the application it does not return the pressure value. Is there any class related to VISA  need to add while building the application? I have LabVIEW version 18. and I have already installed the NI VISA Driver.
(2,738 Views)
Accepted by topic author GAYATRI_D
Are you testing this exe on the same computer on which you build it? If not you also need to make sure to install the NI-VISA Runtime installer on that computer.
Rolf Kalbermatter  My Blog
(2,706 Views)
I have Installed the NI-VISA Runtime installer. And now VISA worked in exe . Thank you for giving the solution.
(2,689 Views)
