Why XControl's reference is invalid?
There are 60 XControls on front panel.I get their reference by a subvi and then output their label text by property node.It's ok when vi run in labview 8.5 IDE.Then I build the program to exe file.The refrence is invalid when I run the exe file .So what's wrong about the exe file?
Thanks!
Message 1 of 11
(7,507 Views)
My English is poor...Do I  say it not clearly?I am looking forward to some help,thanks!
Message 2 of 11
(7,473 Views)
Did you include your Xcontrol when creating exe? If you did, where did you include it? In the Startup VIs or Always included?
And, How do you get the Xcontrol's reference? Could you attach your Code?
Regards
Message 3 of 11
(7,466 Views)
I hava sloved my problem .The problem occured when a common reference  translated into special reference .Jsut like the image:
 When running the exe file,CargoBlock reference is invalid.But I change the method that gets CargoBlock reference ,as follows:
The problem disappears...
Message 4 of 11
(7,460 Views)
So,what's different between 3.jpgand4.jpg?Thanks!
Message 5 of 11
(7,459 Views)
I think the first one is the reference of a control, whereas the second a kind of class.
Regards
Message 6 of 11
(7,451 Views)
I'm fairly sure that this should work and does work with normal control. I would suggest escalating it to make sure.
___________________
Try to take over the world!
Message 7 of 11
(7,444 Views)
Hi,tst
I don't understand your  thought.Could you say it in detail?
Message 8 of 11
(7,433 Views)
My suggestion was for Yan Wu. I don't have enough experience with XControls, but I think it's a bug, so I suggested that Yan Wu check this with other people inside NI.
___________________
Message 9 of 11
(7,431 Views)
Thanks for your advice.
I'll talk with them.
Regards
Message 10 of 11
(7,426 Views)
