Why am I unable to connect to new sub-vi connector pane?
It has happened several times now where I have developed a new sub-vi for use in a vi. I'll build the connector pane in the same way as usual, and save the sub-vi, but when I drop an instance of the sub-vi on my diagram, I am unable to wire to the terminals of the sub-vi. I have only noticed this problem after upgrading to LabVIEW 2011, and the problem is inconsistent. Most times new sub-vis connect with no problem. If I go back into the sub-vi and change the connector pane pattern, I'll usually be able to then connect in the calling vi.
(2,471 Views)
This has been raised as a bug, CAR#318144.
See this thread
Chris Vann
Certified LabVIEW Architect
(2,465 Views)
