Why am i getting coercion dots on boolean inputs?
I have developed the code attached and am curious as to the reason for the coercion dots on my boolean input to an AND logic gate, i didn't think that coercion dots were possible on boolean?!  The System Controls cluster is a strict type def control (also attached).
Any explanation would be appreciated.
Regards
Chris
P.s. Let me know if you need any more of the code.
(3,393 Views)
Accepted by topic author ChrisWoodhams
This should answer your question.
(3,391 Views)
Thank you for your fast response.
I interpret from those other posts that it isn't possible to get rid of my coercion dots unless i drop the strict type def of my boolean control?
Regards
Chris
(3,374 Views)
Yes, you're right !
(3,365 Views)
Thanks very much for your replies!
Chris
(3,350 Views)
