Why are the bounds so large in this graph?
In the attached VI, the "bounds" of the graph are far too large.  How do I shrink the "bounds" back to a reasonable size (that property is not writeable)?
This problem developed when I was changing the "plot area bounds" with a property node in order to move the graph with respect to other FP ojects.  How should I understand the difference between "bounds" and "plot area bounds"?  What is the proper way to change the position of a graph using code?
Allan
(2,548 Views)
Allan,
  This is a good question. Programmatically this is not possible and will have to be done manually as covered in this KB. You can change things like the text size and Plot Area:size to change the height but most of these are manually set.
Hope this helps!
Ben J.
(2,509 Views)
