Why can't I create an executable with LV's application builder that allows multiple instances?
I've created a successful executable, but when I double-click on it a second time, the focus just jumps to the already open program.  Is there a way to allow for another instance of my program to open just like Word or Excel does?
Jeff
(3,173 Views)
Add allowmultipleinstances=true to the ini file of the executable and you should be fine.
(3,167 Views)
I have the executable using my own custom *.ini file, not the LabVIEW generated default.  I still added your suggestion, but nothing different happened.  Is there a setting in the Application Builder wizard?
(3,160 Views)
There is not a flag I know of in the app builder that will add that.  The only way I know of allowing multiple instances is to have the mentioned setting in the applications ini.
The ini should end up having at the least
[app name]
You should still be able to have your custom information in the ini.
(3,150 Views)
It worked!  I had to add a new section.  My executable is titled "MA47.exe", so I added the following lines:
[MA47]
Thanks alot!
(3,142 Views)
