Why can't I open a VI which was saved on an NFS network drive?
When a VI is saved locally on a PC hard drive, there is no problem opening the VI. When saved on an NFS drive, Labview keeps asking for me to locate the VI.
(2,520 Views)
Does this happen for all VIs? It is my guess that the VI is corrupted which is causing it to look for itself. If this is the only VI, you will need to restore from backup.
(2,520 Views)
