Why can't MathLab read NI wav files? Compression type errors from wav header.
Can you use the AU fileformat instead? This is very simple to use. As the endian format fits Labview very well
http://en.wikipedia.org/wiki/Au_file_format
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 11 of 12
(833 Views)
Sorry, I've been out of town. I checked with my MATLAB guru and he states that "after every "tag" (such as the word "data") in the wave file is a number that tells how many bytes are following. There must be an error in the number of bytes in the wav file you are using". I hope this helps you find the problem.
Message 12 of 12
(820 Views)
