Why can't a reentrant dynamic dispatch method preallocate clones?
Does anybody know why a reentrant dynamic dispatch method cannot preallocate clones? The VI breaks unless you set shared clones.
LabVIEW 2012
(3,636 Views)
The limit makes recursion impossible for dynamic dispatch vi's  (can you imagine a large number of sibling methods called with deep recursion? Ouch my memory hurts!)
(3,633 Views)
Thanks - I even looked on Lava and didn't find it!
LabVIEW 2012
(3,613 Views)
@nathand wrote:
A bit more information here: http://lavag.org/topic/10539-reentrant-vi-with-dynamic-input-terminal-must-use-share-clones-between-...
I have to admit.  Steve Mercer explained it to me at a LUG (OK to the LUG) I'm still betting that this will eventaully be worked around by LabVIEW R&D.  When the use cases make the investment worthwhile
(3,605 Views)
I might be missing something, but it seems to me this would be difficult.  With dynamic dispatch, you don't know which VI will be called at run-time, so you can't specifically pre-allocate a copy of a VI for that call.  Instead, LabVIEW would need to pre-allocate a copy of every VI that could possibly be called, and it would need to do this any time a class is loaded at run-time as well.  That's potentially a lot of copies of VIs allocated "just in case."
(3,603 Views)
I couldn't see any technical reason it would be impossible to allow preallocated colones for dynamic dispatched methods. I do understand how it would be impractical or difficult to implement. But then reentrancy was extremely difficult anyway. I think it took a year or two to get it working and resulted in a complete overhaul of the low level parts of LabVIEW.
LabVIEW 2012
(3,566 Views)
