Mac-g wrote in message news:<506500000008000000E4510000-1023576873000@exchange.ni.com>...
> After installing and configuring a NI 8-port RS-232 board using
> LabVIEW's visaconf utility (Linux), only ports 1 through 6
> (ASRL5::INSTR thru ASRL10::INSTR) were ENABLED and READY. Ports 7 & 8
> (ASRL11::INSTR & ASRL12::INSTR) were ENABLED and UNCERTAIN. Both
> 'visaconf' and LabVIEW do not recognize the two ports that are
> "UNCERTAIN." I know ASRL10 - ASRL13 are traditionally mapped to
> parallel ports, however, ASRL10 works fine. How can I get LabVIEW to
> recognize ports ASRL11 & ASRL12?
Hi Mac,
I think the problem stems from the default setup of the visaconf.ini
file.
Have a look at the following URL.
http://digital.ni.com/public.nsf/3efedde4322
fef19862567740067f3cc/6e1c422eea4d54f286256ada0053fba2?OpenDocument
Hope this helps
Sacha
