Why do I get Memory.cpp Line 1038?
I'm having trouble with a large application that exits unexpectedly with the message. "Memory.cpp line 1038"
Does anyone have a idea what might be causing this error code?
Jim West
Summitek Instruments
(2,922 Views)
I believe that the error occurs in the Storage VI library.
I have isolated the issue to a section of code in a VIT.  The VIT is spawned off dynamically.
If I remove the code from the dynamic VI.  The error does not occur.
This section of code uses the Storage VIs to open a TDM file, close a TDM file, read a group, channels etc.
I am curious whether other users with the issue are using Storage Library.
Jim West
(2,919 Views)
Hi Jim,
We've received your error report, and another engineer will respond to that in the near future.
(2,875 Views)
