Why do I get a error 56 when switching the target
I am using labview 7.1, SIT 2.0.2 and labviewRT 7.1. The problem I facing is when I switched the target from local host to RT target I get an error " error code 56:The network operation exceeded the user-specified or system time " Don't know what I' doing wrong. Plz help me out.
Thanks in advance
Ravi
(2,542 Views)
Ravi,
One common cause of receiving error 56 would be that the MAC address that you are inputing to the VI is incorrect or formatted incorrectly. The form of a MAC address is actually in hex, so make sure that your string control or constant is displaying it's data in hex format. If the control or constant is in hex format the MAC address will look something like:  0080 2F0A 14FF
If your string control or constant is not in hex format, right-click on it and select "Hex Display".
(2,527 Views)
