Why do I get an Error Code 70229 when running Block Diagram ?
Hi everyone,
This error is very weird because at one time I got the block diagram to run and it worked well then when I tried it again after reopening the block diagram I got this error .
Can someone help me please ?
I am using SolidWorks Premium 2014 x64 Edition.
The attached files show the version I got for SoftMotion and for Labview 2013 32 bit installed .
PS. I had Labview 2013 64 bit installed but I removed it. not sure if any files remained that may cause this...
Thank you,
Isaiah
(2,776 Views)
Read related topic
Thank you & Best regards
syrpimp
“You must continue to gain expertise, but avoid thinking like an expert." -Denis Waitley
(2,739 Views)
