Why do I get an error 10612 when trying to readback from a line on an output port of a PCi-6527?
I am configuring the port (Port 3) as all outputs (even though it is not software configurable, I wanted to get a Task ID for it the first time that I use it). I can set the bit OK using a Port Write, but then when I follow that with a Port Read, I get the 10612 error. The manual says you can readback from the port, and the data that I'm getting seems correct, yet I still get that error. Is this normal, or is there a better way to implement this. I'm just getting started on my first project, and these simple things are frustrating.
Thanks.
(2,960 Views)
The 10612 error code that you are receiving is not actually an error but a warning. The NI-DAQ Function Reference Manual for DIG_In_Prt states that if you call this function on an output port that has readback capability, +10612 will be returned along with the state of the output port. Apparently, this information was not included in the LabVIEW On-line Help. Generally, you can ignore this warning.
Erin
(2,960 Views)
