Why do I get two different results from the same coefficients?
I am getting two different results from the Polynomial Evaluation function.
For the first one, I am getting the coefficients from a Polynomial Fit function.  I feed the coefficients from the Fit function into the Poly Eval function and get the correct result of 12.8582 when I evaluate 49940.
For the second one, I create constant array of the SAME values that were returned from the Polynomial Fit function (i typed them in).  However, I am getting an incorrect result of -120.7913 when I feed the constant array into the Poly Eval function when I evauate 49940.
How can this happen when I am using the same array values?
Attached is an image of what I am explaining.
(3,009 Views)
Accepted by topic author altran
Hi Altran,
are you sure about using the "same" coefficients?
Did you compare them? Did you (atleast) set the display properties to 17 significant digits?
Please attach a VI instead of a picture...
(2,999 Views)
Which version of LabVIEW are you using?
(2,988 Views)
GerdW,
Thank you, you are correct.  I set the Significant digits to 30 and it worked.  It just "looked the same" when they were both rounded to 6 sig figs.  Another lesson learned, Thanks again!!!
-Andy
(2,965 Views)
GerdW,
-Andy
(2,964 Views)
