01-26-2006 06:42 PM
01-27-2006 02:02 PM
I think the boolean (binary) ops are the only difference between the two nodes. I pulled this from the help:
The following list contains the names of the Formula Node and Expression Node functions, and their descriptions. Except for the binary functions, you also can use these functions with Formula VIs. All function names must be lowercase. You also can use operators and the pi constant in Formula and Expression Nodes.
01-29-2006 10:41 AM
