Why do the shortcut menus I create dynamically not fire events?
In the attached VI I create both application menu items and shortcut menu items both statically and dynamically on both the top level and sublevel (eight combinations in all).  All the menu items should fire an event and populate the ItemTag string with their ItemTag.  They all work except for the dynamically created ones on the shortcut menu (Shortcut 2 and Shortcut 4).  Why don't these cause an event to be fired?
Robert Mortensen
CLA, CLED, LabVIEW Champion, Principal Systems Engineer, Testeract
(2,848 Views)
using the wrong event to catch the shortcut selection...
Mike...
Make sure you get the edited one, I attached the wrong thing the first time.
Message Edited by mikeporter on 06-29-2007 11:24 AM
Certified LabVIEW Architect
LabVIEW Champion
(2,837 Views)
That did it, thanks Mike!
Robert Mortensen
(2,828 Views)
Also, shortcut 4 isn't showing up because you have the wrong menu tag. You had "shortcut to shortcut 2" or something of that nature.
Mike...
LabVIEW Champion
(2,823 Views)
