Why do waveforms show garbage in the plot legend and why is no one mentioning this?
I have tried this on multiple machines and the result is the same. The plot legend expands and shrinks with garbage characters each time the waveform is updated.
Sometimes the plot legend expands to as many as 100 garbage characters (or more). Is NI aware of this?
Message 1 of 9
(3,649 Views)
hi there
i have never encountered this problem on my machine (LV 7.0). can you please post a example cause i have several apps using waveforms and i want to be sure that tehre is no problem?
regards
chris
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Message 2 of 9
(3,649 Views)
"... and why is no one mentioning this?"
I will speak for myself and say that I have never seen this.
Could you please post an example that demonstates this behaviour?
If there is a problem, I want to know about it.
What version of LV?
Is it a chart or a graph?
Curious and trying to help,
Ben
Message 3 of 9
(3,649 Views)
Hi Ben
Ok I managed to get a small enough version of it to zip it up and show what happens. I hope the demo is intact enough to show the plot legend.
just run the VI "0_bloat-OVEN.vi"
It uses a simulation file for the waveform but if u have a DAQ bd just uncheck the "Simulate DAQ bd?" button.
Ive seen this on 3 machines now WIn 98 WIn XP and Win2K.
Message 4 of 9
(3,649 Views)
What are the channel names as defined in MAX?
Message 5 of 9
(3,649 Views)
...or
Right click on chart.
select "plots" tab.
Click the "Do Not Use Waveform Names for Plot Names".
The reason I never saw this is that this is a new property (to me).
I used to have to set these values explicitly.
I hope this help,
Ben
Message 6 of 9
(3,649 Views)
Hello
I tested your program and , if channels have no name, results for plot name are garbage as you state.
If you name channels , the names are ok, since plot name is a waveform attribute.
I never found this problem because I use named and configured channels by means of NI-MAX, but I guess this shoud not happen if name of channel is empty.
My test setup: NI-MAX 3.1 / LV 7.1 / NI-DAQ 7.2 / PCI 6052E
Hope it helps.
"Qod natura non dat, Salmantica non praestat"
Message 7 of 9
(3,649 Views)
I gotta admit
You guys are all pretty sharp.
IT never occured to me to use Max or to even look at the chart properties.
Thanks for helping clear up this mystery for me.
Message 8 of 9
(3,649 Views)
I have a group of CLD I mentor and support that have a running joke going.
It seesm all of my answers start with one of the following phrases.
1) "In the old days....."
2) "Flip it over." (i.e. show diagram)
3) "Show VI Hiarchy."
4) "Right-click"
Many mysteries in LV can be answered by starting with a right-click.
Ain't LV cool!
Ben
Message 9 of 9
(3,649 Views)
