Why does HTTP sends a LVWSAuthSvc Get?
I am exploring the possibilities of the new HTTP protocol implementation in LabVIEW 2010.
Doing some debugging with Microsoft network monitor that with every HTTP Init a HTTP Get is sent with the following content:
GET /LVWSAuthSvc/GetAggregateUserPermissions?username= HTTP/1.1..Host: api.imgur.com..Accept: */*....
This is quite strange to me, or am I missing something?
Ton
My LabVIEW Ideas
Message 1 of 10
(5,940 Views)
Did you ever get any feedback on this? I am using HTTP Get for an internal application that we are building, and the communication is failing due to this. Is this only designed to work against LabVIEW web services?
Chris
Message 2 of 10
(5,790 Views)
If I understand correctly  uit what that message means and wrote it below.
Initial Request Line
The initial line is different for the request than for the response. A
request line has three parts, separated by spaces: a method name, the
local path of the requested resource, and the version of HTTP being used. A
typical request line is:
GET /path/to/file/index.html HTTP/1.0
Notes:
  • GET is the most common HTTP method; it says "give me this resource".
    Other methods include POST and HEAD-- more on those later. Method names are always uppercase.
  • The path is the part of the URL after the host name, also called the
    request URI(a URI is like a URL, but more general).
  • The HTTP version always takes the form "HTTP/x.x", uppercase.
 I think that the links below would be useful too.
http://forums.ni.com/t5/LabVIEW/How-do-I-send-an-HTTP-request-to-a-web-server-using-the-TCP/m-p/2286...
http://www.jmarshall.com/easy/http/
http://en.wikipedia.org/wiki/Hypertext_Transfer_Protocol
Regards
Message 3 of 10
(5,770 Views)
Hi Ton (TCPlomp),
My name is Charles and I am the engineer behind the HttpClient.
What you uncovered was a bug in LabVIEW 2010 that we fixed in LabVIEW 2011 (CAR# 288076).  In LabVIEW 2010 and LabVIEW 2010SP1, we incorrectly hit the network wire to attempt to log into a webservice, regardless as whether user wished to do this or not.  This is not a fatal error and can simply be ignored.  Sorry for the confusion.
If you have any additional questions, feel free to ask.
Charles
Message 4 of 10
(5,740 Views)
Hi Charles,
I have labview 2010.
I am not particularly interested in upgrading.
I need to make use http post through labview.
I get the same error as described above.
What are my options for getting around this bug?
Is there some sort of patch I can download for this?
Message 5 of 10
(5,608 Views)
Hi Charles,
My name is Alejandro,
I have the same problem.
Is there some patch to solve this problem in LabVIEW2010 SP1?. We can't change our LabVIEW developper version at this time
Regards
Message 6 of 10
(5,428 Views)
@Alejandro_i wrote:
Hi Charles,
Regards
Did you read his note? "This is not a fatal error and can simply be ignored."
(blog)
Message 7 of 10
(5,402 Views)
Yes, I did.
But we have one customer with this issue:  After calling some unavailable method on his WebServer, it avoid any another http request during certain amount of time from the same IP. He tells me the reason is for security policy
Regards
Message 8 of 10
(5,377 Views)
Well then you will need to:
a) Get them to make an exception to their security policy
b) Update your software to use a newer version of LabVIEW where the bug is not present
c) Perhaps you could make a firewall rule to block the outgoing request
d) Rewrite the HTTP method using the raw TCP functions
(blog)
Message 9 of 10
(5,362 Views)
Thanks for the info!
We will rewrite HTTP method using TCP functions because we can't change our LabVIEW version
Regards
Message 10 of 10
(5,330 Views)
