Why does LabVIEW take all day to install on one PC?
I hate when we build a standalone machine and the customer's IT department insists on putting stuff on it. 99% of the time the computer is NOT connected to the network or internet but they still have to weasel some "protective" software on it.
Message 11 of 29
(6,092 Views)
Is your hard disk dying?  Slow performance is often the harbinger of death (especially if accompanied by occassional thunks as the drive tries to recalibrate itself).  We use McAfee and I can usually get LabVIEW and the driver CD on in under two hours.  I have a two year old PC, although it does have a RAID 5 disk system.
That said, if you have an older version of McAfee, that could be the issue.  McAfee updated their on-demand scanning a couple of years ago and made it much faster.
Message 12 of 29
(6,079 Views)
I agree with you.  The latest version of LV is bloated.
It installs tons of extra stuff that I don't use.  And all the components seems to be dependant on each others, so its hard to do a minimal install.  NI's release engineers need to work in this, IMHO.
And that pesky NI Update Service is a pain.
http://www.medicollector.com
Message 13 of 29
(6,060 Views)
Yes, it is bloated...automatically installs packages that I don't want to activate after 30 days and then it's hard (and time consuming) to get rid of them after the fact. Luckily I don't have to do this that often.
Message 14 of 29
(6,053 Views)
I'm installing Labview2018 on a brand new HP Spectre 360 (Intel i7, 8th Gen) and its still taking way more than 3 hrs (likely won't be complete before 10 hrs).
I'm on Google Fiber as well (1gbps).
This is, by far, the slowest (longest) software download I've encountered and I use a lot of downloadable S/W devel tools and devel env's
Why so long?
Message 15 of 29
(5,782 Views)
Hi @ruggedeye,
Sorry to hear that your installation is taking longer than anticipated - it definitely should not take 10 hours to install. If you'd like to have us look into this further, I would recommend utilizing the Support channel by opening a Service Request at ni.com/support.
Lindsey Nestor
Program Manager, Hardware Services
Message 16 of 29
(5,755 Views)
@ruggedeye wrote:
I'm installing ....
...sis, by far, the slowest (longest) software download ...
You are talking about "install" and "download" and it is not clear from thetcontext what's the limiting step.
Are you using the web based platform installer?
Message 17 of 29
(5,751 Views)
I recently prepared clear OS for a new project. I installed TestStand+LabVIEW (I unchecked most of the recommended SW components for LabVIEW). I end up with 255 components installed!!! What would be the bare minimum? Can't I simply install additional components when they are needed and have better configuration management?
Spoiler
C:\Program Files\National Instruments\NI Package Manager>nipkg list-installed
system-windows-x64 20.5.0.49152-0+f0 windows_x64 Package that indicates the current system is running a 64-bit Windows operating system.
ni-package-manager-released-feed 20.5.0.49152-0+f0 windows_all Provides NI Package Manager released packages.
ni-package-manager-upgrader 20.5.0.49152-0+f0 windows_all Application used to upgrade the package manager.
ni-ssp-notifier 19.0.0.49152-0+f0 windows_all This is an infrastructure package for NI Software.
ni-help-viewer-core 19.0.0.49152-0+f0 windows_all This is an infrastructure package for NI Software.
ni-teststand-2019-package-builder-support-x86 19.0.0.49153-0+f1 windows_all Package Builder support for TestStand 2019
ni-package-builder-core 19.0.0.49152-0+f0 windows_x64 Core support for NI Package Builder
ni-package-builder-core-x86 19.0.0.49152-0+f0 windows_all Core support for NI Package Builder
ni-package-builder 19.0.0.49152-0+f0 windows_all NI Package Builder helps you organize and build your own NI packages, package installers, and feeds. NI Package Builder is a utility that helps you distribute your software. You can use it to organize and build multiple packages and feeds that you can then distribute with Package Manager or SystemLink software. You can also build and distribute stand-alone package installers. Additionally, you can bundle multiple NI product installers into a custom installer.
ni-package-manager-deployment-support 20.5.0.49152-0+f0 windows_all Deployment support for NI Package Manager.
ni-package-manager 20.5.0.49152-0+f0 windows_all NI Package Manager facilitates the installation, removal, and management of NI software.
ni-mstudio-common-help 19.0.0.49152-0+f0 windows_all Measurement Studio Common Library Help for .NET Framework
ni-securityupdate-kb67l8lcqw-killbits 2.1.0.49152-0+f0 windows_all This is an infrastructure package for NI Software.
ni-metauninstaller 20.0.0.49152-0+f0 windows_all This package provides support for uninstallation of NI products.
ni-euladepot 20.0.0.49152-0+f0 windows_all Installs license and notice files.
ni-daqmx-labview-rte-support 20.0.0.49152-0+f0 windows_all This is an infrastructure package for NI Software.
ni-mdfsupport 20.0.0.49152-0+f0 windows_all This package installs the files necessary to support building deployments from NI's ADEs.
ni-assistant-framework-labview-2020-support 20.0.0.49152-0+f0 windows_x64 NI Assistant Framework LabVIEW 2020 64-bit Support contains the LabVIEW project provider file for Assistant Framework.
ni-assistant-framework-labview-2019-support 20.0.0.49152-0+f0 windows_x64 NI Assistant Framework LabVIEW 2019 64-bit Support contains the LabVIEW project provider file for Assistant Framework.
ni-assistant-framework-labview-2018-support 20.0.0.49152-0+f0 windows_x64 NI Assistant Framework LabVIEW 2018 64-bit Support contains the LabVIEW project provider file for Assistant Framework.
ni-assistant-framework-labview-2017-support 20.0.0.49152-0+f0 windows_x64 NI Assistant Framework LabVIEW 2017 64-bit Support contains the LabVIEW project provider file for Assistant Framework.
ni-assistant-framework-ui-assemblies 20.0.0.49152-0+f0 windows_all NI Assistant Framework UI Assemblies contains the UI assemblies used by Assistant Framework.
ni-assistant-framework-labview-2020-x86-support 20.0.0.49152-0+f0 windows_all NI Assistant Framework LabVIEW 2020 32-bit Support contains the LabVIEW project provider file for Assistant Framework.
ni-assistant-framework-labview-2019-x86-support 20.0.0.49152-0+f0 windows_all NI Assistant Framework LabVIEW 2019 32-bit Support contains the LabVIEW project provider file for Assistant Framework.
ni-assistant-framework-labview-2018-x86-support 20.0.0.49152-0+f0 windows_all NI Assistant Framework LabVIEW 2018 32-bit Support contains the LabVIEW project provider file for Assistant Framework.
ni-assistant-framework-labview-2017-x86-support 20.0.0.49152-0+f0 windows_all NI Assistant Framework LabVIEW 2017 32-bit Support contains the LabVIEW project provider file for Assistant Framework.
ni-labview-2019-runtime-engine-resource 19.1.0.49152-0+f0 windows_all LabVIEW 32-bit Runtime Resource contains support for non-English languages to display in dialog boxes, menus, and error messages that are part of the LabVIEW Runtime.
ni-labview-2019-realtime-nbfifo-x86 19.0.0.49152-0+f0 windows_all This is an infrastructure package for NI Software.
ni-logos-xt 20.0.0.49152-0+f0 windows_all NI Logos XT provides a thin layer on top of TCP/IP to simplify some common network tasks.
ni-rpc-19.0.0-realtime-bin 19.0.0.49152-0+f0 windows_all NI Remote Procedure Call library (infrastructure) Provides rpc services to LabVIEW RT NI software.
ni-opc-support 20.0.0.49152-0+f0 windows_all NI OPC Support helps customers using OPC (OLE for process control) to add advanced analysis and control functionality to their system.
ni-labview-2020-measapps-chm 20.0.0.49152-0+f0 windows_all Contains instructions for taking various common measurements in LabVIEW using NI-DAQmx, IVI class drivers, FieldPoint, and so on.
ni-daqmx-labview-shared-docs 20.0.0.49152-0+f0 windows_all This is an infrastructure package for NI Software.
ni-tdms 19.0.0.49152-0+f0 windows_all NI TDM Streaming provides functions to read and write waveforms and waveform properties to binary measurement files (.tdms).
ni-mkl-2018 18.0.1.49152-0+f0 windows_all Math Kernel Library (MKL) is an Intel software package that provides optimized linear algebra routines.
ni-mkl-2017 17.0.1.49152-0+f0 windows_all Math Kernel Library (MKL) is an Intel software package that provides optimized linear algebra routines.
ni-error-reporting-interface 20.0.0.49152-0+f0 windows_all NI Error Reporting Interface provides the error reporting interface for Windows.
ni-labview-c-interface 1.0.4.49152-0+f0 windows_all The LabVIEW C Interface to VI Server enables you to call VIs from C code. You can also call VI Server properties and methods on the Application and VI classes.
ni-msiproperties 20.0.0.49152-0+f0 windows_all Installs the files necessary for Package Manager to resolve NI properties (e.g. the NI Program Files installation directory) and evaluate MSI conditions.
ni-cabled-pcie 20.0.0.49152-0+f0 windows_all NI-Cabled PCIe
ni-pxiplatformsoftware-errors 19.0.0.49152-0+f0 windows_all Error description files for NI PXI Platform Software
ni-pxiplatformframework-errors 19.5.0.49152-0+f0 windows_all NI PXI Platform Framework Error Files
ni-pal-errors 19.5.0.49152-0+f0 windows_all NI Platform Abstraction Layer error code descriptions (infrastructure) Provides core driver services for National Instruments drivers. This package includes descriptions for error codes originating from ni-pal.
ni-roco-errors 20.0.0.49152-0+f0 windows_all NI Routing Coordinator signal routing support library (error descriptions) Provides signal routing services for National Instruments software. This package includes descriptions for error codes originating from ni-roco.
ni-cvi-openmp 19.0.0.49152-0+f0 windows_all Installs the LabWindows/CVI OpenMP Library Runtime.
ni-labview-2018-runtime-engine-resource 18.6.0.49152-0+f0 windows_all LabVIEW Runtime (32-bit) Resource contains support for non-English languages to display in dialog boxes, menus, and error messages that are part of the LabVIEW Runtime.
ni-labview-2018-realtime-nbfifo-x86 18.0.1.49152-0+f0 windows_all NI LabVIEW 2018 Real-Time NBFifo provides support for LabVIEW Real-Time FIFOs on desktop computers.
ni-apal-errors 19.0.0.49152-0+f0 windows_all NI device driver error code descriptions (infrastructure) Error code descriptions common to many National Instruments device drivers.
ni-labview-2020-runtime-engine-resource 20.0.0.49153-0+f1 windows_all LabVIEW 32-bit Runtime Resource contains support for non-English languages to display in dialog boxes, menus, and error messages that are part of the LabVIEW Runtime.
ni-labview-2020-realtime-nbfifo-x86 20.0.0.49152-0+f0 windows_all This is an infrastructure package for NI Software.
ni-opcenum 5.6.3.49152-0+f0 windows_all OPCEnum application runs locally on the serving computer and exposes available OPC servers to the remotely connecting clients.
ni-usblan 19.0.0.49153-0+f1 windows_all This is an infrastructure package for NI Software.
ni-web-pipeline-19.0 19.0.0.49152-0+f0 windows_all This is an infrastructure package for NI Software.
ni-python-interface 20.0.0.49154-0+f2 windows_all NI Python Interface is a common Python interface for all NI products.
ni-mkl-2020 20.0.0.49152-0+f0 windows_all Math Kernel Library (MKL) is an Intel software package that provides optimized linear algebra routines.
ni-labview-max-xml 19.0.0.49152-0+f0 windows_all NI LabVIEW MAX XML installs the XML file for defining visibility of LabVIEW in MAX.
ni-labview-2020-vilib-x86-en 20.0.1.49154-0+f2 windows_all This is an infrastructure package for NI Software.
ni-labview-2020-simulation-x86 20.0.0.49152-0+f0 windows_all Installs files in the LabVIEW addons simulation folder
ni-labview-2020-scripting-codegen-x86 20.0.0.49160-0+f8 windows_all NI LabVIEW 2020 Scripting Code Generator installs the LabVIEW 2020 Scripting Code Generator Engine.
ni-labview-2020-manuals-x86-en 20.0.0.49152-0+f0 windows_all NI LabVIEW 2020 Manuals is used to provide manuals for LabVIEW 2020.
ni-labview-2020-helpchm 20.0.0.49152-0+f0 windows_all Installs LabVIEW 2020 help chm files
ni-labview-2020-help-x86-en 20.0.0.49152-0+f0 windows_all NI LabVIEW 2020 Help is used to provide help information for LabVIEW 2020.
ni-labview-2020-executable-x86 20.0.1.49153-0+f1 windows_all This is an infrastructure package for NI Software.
ni-labview-2020-example-x86-en 20.0.0.49152-0+f0 windows_all This is an infrastructure package for NI Software.
ni-json-map 20.0.0.49152-0+f0 windows_all NI JSON Map Files contains the information about NI Component locations for better error messaging with missing subVIs.
ni-iioa-labview-2020-support-x86 20.0.0.49152-0+f0 windows_all Provides NI Instrument I/O Assistant Core Support for LabVIEW 2020 (32-Bit).
ni-codesignapi 19.0.0.49156-0+f4 windows_all This package installs the NI CodeSignAPI DLL.
ni-assistant-framework-labview-2020-codegen-x86-support 20.0.0.49152-0+f0 windows_all NI Assistant Framework LabVIEW Code Generator 2020 (32-bit) is used to install Engine Entry Points for LabVIEW 2020 Code Generator.
ni-assistant-framework 20.0.0.49152-0+f0 windows_x64 NI Assistant Framework (64-bit) is a toolset for making software applications, with a particular emphasis on tools needed for measurement applications.
ni-cvi-tdms 19.0.0.49152-0+f0 windows_all The LabWindows/CVI TDM Streaming Library Runtime contains functions that you can use to log large amounts of test data quickly.
ni-cvi-analysis 19.0.0.49152-0+f0 windows_all The LabWindows/CVI Analysis Library Runtime provides functions for 1D and 2D array manipulation, complex operations, matrix operations, and statistics.
ni-mssilverlight 5.1.9.49152-0+f0 windows_all NI installer for Microsoft Silverlight. Required by some National Instruments products. Refer to the descriptions of your selected products to determine whether you should include Silverlight in your installer.
ni-msdotnet4x 4.6.3.49152-0+f0 windows_all NI installer for Microsoft's .NET Framework 4.6.2
ni-msvcrt-2015 14.1.5.49152-0+f0 windows_all NI installer for Microsoft Visual C++ 2015 Run-Time Update 3 (includes KB3118401)
ni-cvi-usi 19.0.0.49152-0+f0 windows_all Installs the LabWindows/CVI Diadem Connectivity Support. It contains the deprecated cviusi.dll.
ni-cvi-runtime-realtime 19.0.0.49152-0+f0 windows_all Installs run-time support for DLLs targeted for a real-time system.
ni-cvi-opengl 19.0.0.49152-0+f0 windows_all Installs the LabWindows/CVI OpenGL Library Runtime.
ni-cvi-internet 19.0.0.49152-0+f0 windows_all The LabWindows/CVI Internet Library Runtime provides functions for Internet protocols like FTP, POP3, Telnet, etc. You can distribute the Intenet Library according to your license agreement.
ni-cvi-instrsup 19.0.0.49152-0+f0 windows_all Installs run-time support only for instrument drivers and a limited set of LabWindows/CVI library functions. This package allows other applications to use instrument driver DLLs without having to load the larger LabWindows/CVI Run-Time DLL.
ni-cvi-datasocket 19.0.0.49152-0+f0 windows_all The LabWindows/CVI DataSocket Library Runtime functions simplify live data exchange between applications. You can distribute the DataSocket Library according to your license agreement.
ni-pie 20.0.0.49152-0+f0 windows_all This is an infrastructure package for NI Software.
ni-assistant-framework-custom-ui-tool 20.0.0.49152-0+f0 windows_all NI Assistant Framework Custom UI contains the custom UI files of Assistant Framework.
ni-launcher 20.0.0.49152-0+f0 windows_all NILauncher is for browsing and launching National Instruments software installed on your computer. Installs on Windows 8.x and newer.
ni-search-x86 20.0.0.49152-0+f0 windows_all NI Search Shared Engine provides libraries and other files necessary to run search in NI applications.
ni-labview-broker 6.8.3.49152-0+f0 windows_all NI LabVIEW Broker enables a C++ app to run VIs and interact with LV.
ni-cvi-codegen 19.0.0.49152-0+f0 windows_all The LabWindows/CVI Code Generator for the NI Assistant Framework.
ni-resetniconfig 19.0.0.49152-0+f0 windows_all NI Reset Configuration is a utility used to reset all NI device configuration settings.
ni-max-rempxi-provider 19.0.0.49152-0+f0 windows_all Provides remote configuration of NI Real-Time PXI targets in Measurement & Automation Explorer (MAX).
ni-wsrepl 20.0.0.49152-0+f0 windows_all NI WS Repl Library 2020
ni-metasuite 19.0.0.49156-0+f4 windows_all This package provides support for creating Suited installers.
ni-tdm-excel-addin 19.0.0.49152-0+f0 windows_all Extends the capabilities of Microsoft Excel by adding the ability to load TDM or TDMS files written with NI hardware and application software.
ni-help-assistant 2.2.0.49152-0+f0 windows_all Provides support for displaying NI HTML help files.
ni-xerces-delay-load 2.7.10.49152-0+f0 windows_all NI Xerces Delay Load Software provides the XML parsing and transforming functionality to user applications.
ni-portable-configuration 19.5.0.49152-0+f0 windows_all Used by National Instruments components to archive and deploy configuration settings.
ni-traceengine 20.0.0.49152-0+f0 windows_all NI Trace Engine
ni-mstudio-cw3dgraph 8.7.5.49152-0+f0 windows_all The National Instruments Measurement Studio 3DGraph ActiveX control.
ni-logos 20.0.0.49152-0+f0 windows_all NI Logos provides support for the network protocol that uses network-published shared variables.
ni-error-report-x86 20.0.0.49152-0+f0 windows_all NI Error Reporting (32-bit) enables you to send NI a crash or internal warning report.
ni-auth 20.0.0.49152-0+f0 windows_all NI Authentication
ni-mstudio-common-fx40-19.0.0-runtime 19.0.0.49152-0+f0 windows_all Measurement Studio Common Library Runtime for .NET Framework 4.0
ni-rpc 19.0.0.49152-0+f0 windows_all NI Remote Procedure Call library (infrastructure) Provides rpc services to NI software.
ni-svcloc 20.0.0.49152-0+f0 windows_all NI Service Locator 2020 The NI Service Locator facilitates communication between National Instruments support programs and services that use local, dynamic TCP ports to communicate with each other.
ni-ssl-support 20.0.0.49152-0+f0 windows_all NI SSL Support helps you enable Secure Sockets Layer (SSL) encryption on the Web Server.
ni-pcibrd 20.0.0.49152-0+f0 windows_all NI-PCI Bridge Driver
ni-apxipm2 19.1.0.49152-0+f0 windows_all NI Atomic 2.0 PXIe Peripheral Module Driver
ni-mxlc-core 20.0.0.49152-0+f0 windows_all Provides binaries required by NI-MXLC.
ni-cvi-2019-reflector 19.0.0.49152-0+f0 windows_all The LabWindows/CVI .NET Reflector Runtime provides functions that facilitate calling .NET assemblies
ni-xlator 19.5.0.49152-0+f0 windows_all NI error message translation and localization library NI-Xlator translates, when available, error messages into the language of the host system.
ni-pal 20.0.0.49152-0+f0 windows_all NI Platform Abstraction Layer hardware support library Provides core driver services for National Instruments drivers.
ni-ede 19.0.0.49153-0+f1 windows_all NI Ethernet Device Enumerator (infrastructure) Performs discovery and enumeration of embedded ethernet interfaces.
ni-lv-web-server-labview-2020-x86-support 20.0.0.49152-0+f0 windows_all NI LabVIEW 2020 Web Server.
ni-dataplugins-python-host 19.6.0.49153-0+f1 windows_all NI DataPlugins Python Host
ni-datafinder-desktop-quit-dc 19.6.0.49152-0+f0 windows_all Quit of DataFinder Desktop
ni-activex-container 17.1.2.49152-0+f0 windows_all NI ActiveX Container enables you to embed ActiveX objects on the front panel of a VI.
ni-mesa 17.1.1.49152-0+f0 windows_all Mesa is an open-source implementation of the OpenGL specification that is a system for rendering interactive 3D graphics.
ni-systemlogging-utils 20.0.0.49152-0+f0 windows_all NI System Logging Utilities
ni-slcp-x86 4.1.1.49152-0+f0 windows_all The NI Software License Compliance Program (32-bit) is a mechanism within LabVIEW that records and sends to NI only the critical information necessary to validate legal compliance with NI licensing policies.
ni-package-builder-labview-2020-support-x86-en 20.0.0.49152-0+f0 windows_all Allows building packages from LabVIEW 2020 (32-bit)
ni-labview-2020-coreother-x86-en 20.0.0.49152-0+f0 windows_all This is an infrastructure package for NI Software.
ni-license-manager 4.6.0.49152-0+f0 windows_all NI License Manager is an application that helps you manage licensed NI software assets. NI License Manager is a tool designed to help you activate, deactivate, and transfer software products using license activation codes or license files. License administrators can use NI License Manager to automate product activation and add volume license servers.
ni-daqmx-common-docs 20.0.0.49153-0+f1 windows_all This is an infrastructure package for NI Software.
ni-search-labview-2020-support-x86 20.0.0.49152-0+f0 windows_all NI Search LabVIEW 2020 Support provides libraries and other files necessary to run search in LabVIEW 2020.
ni-update-service 19.0.0.49152-0+f0 windows_all NI Update Service checks for and electronically delivers software updates for NI software and drivers.
ni-max-software-provider 19.0.0.49152-0+f0 windows_all Provides software configuration in Measurement & Automation Explorer (MAX).
ni-labview-system-state-publisher 20.0.0.49152-0+f0 windows_all NI System State Publisher provides System State Publisher support for LabVIEW.
ni-deployment-framework-x86 20.0.0.49152-0+f0 windows_all Provides a framework to support RT or assembly deployment.
ni-cvi-networkstreams 19.0.0.49152-0+f0 windows_all The LabWindows/CVI Network Streams Library Runtime provides functions for reading and writing data to network streams. You also can use the Network Streams Library functions in real-time (RT) applications.
ni-cvi-network-variable 19.0.0.49152-0+f0 windows_all The LabWindows/CVI Network Variable Library Runtime provides functions for reading and writing data to network variables. You can use the functions in this library to communicate with LabVIEW shared variables and Measurement Studio network variables. You also can use the Network Variable Library functions in real-time (RT) applications.
ni-logos-labview-2020-support-x86-en 20.0.0.49152-0+f0 windows_all NI Logos LabVIEW 2020 Support is used to provide LabVIEW 2020 Support for Logos Networking Technology.
ni-datasocket 20.0.0.49152-0+f0 windows_all Support for built applications or shared libraries that use DataSocket. This installer includes the DataSocket Server, DataSocket Server Manager, and OPC Demo Server.
ni-mxs 20.0.0.49152-0+f0 windows_all Provides an internal configuration database for NI software and hardware.
ni-mdnsresponder 19.0.0.49152-0+f0 windows_all Used by National Instruments components to advertise and discover Zeroconf devices and services. NI mDNS Responder Service advertises and discovers Zeroconf devices and services. If this service is stopped, advertisement and discovery of devices and services will no longer function. If this service is disabled, any services that explicitly depend on it will fail to start.
ni-ssl-labview-2019-runtime-engine-x86-support 19.0.0.49152-0+f0 windows_all Installs LabVIEW 2019 runtime support files for SSL technologies.
ni-system-webserver-base 20.0.0.49152-0+f0 windows_all NI System Web Server Base 2020
ni-webserver 20.0.0.49152-0+f0 windows_x64 The NI Web Server hosts web applications and web UIs.
ni-curl 20.0.0.49152-0+f0 windows_all NI Curl provides the build of the "C URL" library that is an open-source command line tool and library for transferring data with URL syntax.
ni-ssl-labview-2018-runtime-engine-x86-support 18.0.1.49152-0+f0 windows_all Installs LabVIEW 2018 runtime support files for SSL technologies.
ni-ssl-labview-2020-runtime-engine-x86-support 20.0.0.49152-0+f0 windows_all Installs LabVIEW 2020 runtime support files for SSL technologies.
ni-ssl-labview-2020-x86-support 20.0.0.49152-0+f0 windows_all Installs LabVIEW 2020 support files for SSL technologies.
ni-mxlc 20.0.0.49152-0+f0 windows_all NI mx List Control Terminal I/O support library (infrastructure) Provides infrastructure services for Terminal I/O controls in National Instruments software.
ni-cvi-dotnet 19.0.0.49152-0+f0 windows_all The LabWindows/CVI .NET Library Runtime provides functions that facilitate calling .NET assemblies.
ni-orb 20.0.0.49153-0+f1 windows_all NI Object Request Broker driver support library (infrastructure) Provides core services for National Instruments software.
ni-web-services-labview-2020-x86-support 20.0.0.49152-0+f0 windows_all Installs Web Services Runtime Components.
ni-usi-core 19.6.0.49153-0+f1 windows_all NI USI Core provides components for NI TDM software NI USI Core provides components for NI TDM software and allows access to any file format using DataPlugins.
ni-cvi-activex 19.0.0.49152-0+f0 windows_all The LabWindows/CVI ActiveX Library Runtime provides functions for ActiveX programming. You can distribute the ActiveX Library according to your license agreement.
ni-cvi-labview-dll-builder-15.1.0 15.1.1.49152-0+f0 windows_all This is an infrastructure package for NI Software.
ni-mstudio-common-fx40-19.0.0-development 19.0.0.49152-0+f0 windows_all Measurement Studio Common Library Development for .NET Framework 4.0
ni-labview-2020-license 20.0.0.49152-0+f0 windows_all NI LabVIEW 2020 License is used to install license files for LabVIEW 2020.
ni-labview-2020-deployable-license 20.0.0.49152-0+f0 windows_all NI LabVIEW 2020 Deployable License contains components to support remote panel licenses.
ni-variable-engine 20.0.0.49152-0+f0 windows_all NI Variable Engine supports applications that read and write live data using shared variables. You must install this engine if you host, configure, or create shared variables in your application.
ni-pxiplatformservices-expert 20.0.0.49152-0+f0 windows_all NI PXI Platform Services MAX Expert
ni-lv-web-server-labview-2019-runtime-engine-x86-support 19.0.0.49152-0+f0 windows_all Include this component when using the Web Server for stand-alone applications and shared libraries.
ni-system-webserver-appserver 20.0.0.49152-0+f0 windows_all Include this component when using Web Services built with LabVIEW.
ni-sysapi 20.0.0.49152-0+f0 windows_all Provides an internal interface for enumerating and configuring devices.
ni-syncdomain-service 20.0.0.49152-0+f0 windows_all Provides support for using NI Sync Domain.
ni-lv-web-server-labview-2018-runtime-engine-x86-support 18.0.1.49152-0+f0 windows_all Include this component when using the Web Server for stand-alone applications and shared libraries.
ni-lv-web-server-labview-2020-runtime-engine-x86-support 20.0.0.49152-0+f0 windows_all Include this component when using the Web Server for stand-alone applications and shared libraries.
ni-mxlc-labview-2020-support-x86 20.0.0.49152-0+f0 windows_all NI mx List Control Terminal I/O support library LabVIEW 2020 32-Bit Development Support(infrastructure) Provides LabVIEW 2020 32-Bit development support for infrastructure services for Terminal I/O controls in National Instruments software.
ni-mdbg 20.0.0.49154-0+f2 windows_all NI mxDebug driver support library (infrastructure) Provides debugging services for National Instruments software.
ni-variable-engine-labview-2020-support-x86-en 20.0.0.49152-0+f0 windows_all NI Variable Engine LabVIEW 2020 Support is used to provide LabVIEW 2020 Support for Variable Engine.
ni-labview-2019-runtime-engine-x86 19.1.1.49152-0+f0 windows_all The LabVIEW Runtime is a software add-on that enables engineers to run executables on a nondevelopment machine. The LabVIEW Runtime enables you to run executables created with the LabVIEW Application Builder on machines that do not have LabVIEW installed. The LabVIEW Runtime includes the libraries and other files necessary to run basic application types built in LabVIEW.
ni-system-webserver 20.0.0.49152-0+f0 windows_all Support for using Web services to communicate between National Instruments software, such as LabVIEW and NI Measurement & Automation Explorer.
ni-registration-wizard 1.0.8.49152-0+f0 windows_all The NI Registration Wizard is designed to assist in the registration of National Instruments products by using a secure internet connection.
ni-remote-configuration 20.0.0.49152-0+f0 windows_all Provides remote configuration of NI Real-Time targets.
ni-networkdiscoverysvc 20.0.0.49152-0+f0 windows_all Provides network device and service discovery for NI services and applications. NI Network Discovery Service discovers NI Zeroconf devices and services. If this service is stopped components that rely on discovering NI Zeroconf devices and services will no longer function. If this service is disabled any services that explicitly depend on it will fail to start.
ni-mximanager 20.0.0.49152-0+f0 windows_all NI MXI Manager
ni-controllerdriver 20.0.0.49152-0+f0 windows_all NI Controller Driver
ni-roco 20.0.0.49152-0+f0 windows_all NI Routing Coordinator software infrastructure library Provides signal routing services for National Instruments software.
ni-device-monitor 19.0.0.49152-0+f0 windows_all NI Device Monitor is a getting-started utility for launching applications when an NI device is detected.
ni-rtsi-core 20.0.0.49152-0+f0 windows_all This is an infrastructure package for NI Software.
ni-qpxi 20.0.0.49152-0+f0 windows_all NI-Query PXI
ni-dim 20.0.0.49152-0+f0 windows_all NI Device Interconnect Manager driver support library (infrastructure) Provides signal routing services for National Instruments software.
ni-labview-2018-runtime-engine-x86 18.6.4.49152-0+f0 windows_all The LabVIEW Runtime is a software add-on that enables engineers to run executables on a nondevelopment machine. The LabVIEW Runtime enables you to run executables created with the LabVIEW Application Builder on machines that do not have LabVIEW installed. The LabVIEW Runtime includes the libraries and other files necessary to run basic application types built in LabVIEW.
ni-labview-2020-runtime-engine-x86 20.0.1.49153-0+f1 windows_all The LabVIEW Runtime is a software add-on that enables engineers to run executables on a nondevelopment machine. The LabVIEW Runtime enables you to run executables created with the LabVIEW Application Builder on machines that do not have LabVIEW installed. The LabVIEW Runtime includes the libraries and other files necessary to run basic application types built in LabVIEW.
ni-mxdf 20.0.0.49153-0+f1 windows_all NI mx Driver Framework driver support library (infrastructure) Provides infrastructure services for National Instruments software.
ni-realtime-error-dialog 19.0.0.49152-0+f0 windows_all LabVIEW Real-Time Error Dialog enables you to view error logs and generate error reports for sessions of a LabVIEW Real-Time target.
ni-sysapi-webservice 20.0.0.49152-0+f0 windows_all Provides 32-bit web service components for the NI System API Framework.
ni-cvi-runtime-core 19.0.0.49152-0+f0 windows_all Installs run-time support for projects built with full run-time support. This package provides support for most, but not all, of the provided libraries. You will also need to select additional library support if your application calls the corresponding library functions.
ni-syscfg-runtime 20.0.0.49152-0+f0 windows_all Run-time components required to deploy applications that use the NI System Configuration API.
ni-daqmx-devmon-support 19.0.0.49152-0+f0 windows_all This is an infrastructure package for NI Software.
ni-labview-vimerge-x86 20.0.0.49152-0+f0 windows_all NI LabVIEW Merge Utility (32-bit) is a utility to merge LabVIEW VIs.
ni-labview-vicompare-x86 20.0.0.49152-0+f0 windows_all NI LabVIEW Compare Utility (32-bit) is a utility to compare LabVIEW VIs.
ni-distributed-system-manager-2020 20.0.0.49152-0+f0 windows_all Support for creating and monitoring variables, processes, I/O servers, and Web services, as well as interacting with the NI Variable Engine and managing security aliases.
ni-rtsi-pal 20.0.0.49152-0+f0 windows_all This is an infrastructure package for NI Software.
ni-pxiplatformframework 20.0.0.49152-0+f0 windows_all NI PXI Platform Framework supplies PXI system services to NI products.
ni-mru 20.0.0.49152-0+f0 windows_all NI mx Routing Utility driver support library (infrastructure) Provides signal routing services for National Instruments software.
ni-sysapi-wif 20.0.0.49152-0+f0 windows_all Provides WIF components for the NI System API Framework.
ni-cvi-rte 19.0.0.49152-0+f0 windows_all The LabWindows/CVI Shared Runtime Base enables you to run most executables or use most DLLs created with LabWindows/CVI on a machine without the development environment installed. The LabWindows/CVI Shared Runtime Base enables you to run executables or use DLLs created with LabWindows/CVI that do not use separate LabWindows/CVI Shared Runtime libraries, and it must be present on any target computer on which you want to run your executable program. You can distribute the Runtime according to your license agreement. The mark LabWindows is used under a license from Microsoft Corporation. Windows is a registered trademark of Microsoft Corporation in the United States and other countries.
ni-syscfg-dotnet-runtime 20.0.0.49152-0+f0 windows_all Enables you to run applications that use the NI System Configuration .NET API.
ni-targetdiscoverywizard 20.0.0.49152-0+f0 windows_all Diagnoses problems adding a remote system to NI MAX. NI Remote System Discovery Troubleshooting Wizard diagnoses problems with adding a system to Measurement & Automation Explorer (MAX).
ni-syscfg-labview-support 20.0.0.49152-0+f0 windows_all Provides files required to create applications using the NI System Configuration API within LabVIEW.
ni-example-finder-x86 20.0.0.49152-0+f0 windows_all NI Example Finder is a utility that you can browse and search LabVIEW example VIs.
ni-pxiplatformservices-runtime 20.0.0.49152-0+f0 windows_all NI PXI Platform Services Runtime supports NI PXI Chassis and Controllers, implements the PXI specifications, and supplies system services to other NI products.
ni-wifcoredeps 20.0.0.49152-0+f0 windows_all Provides web-based configuration and monitoring pages.
ni-cvi-runtime-engine 19.0.0.49152-0+f0 windows_all The LabWindows/CVI Shared Runtime enables you to run executables or use DLLs created with LabWindows/CVI on a machine without the development environment installed. The LabWindows/CVI Shared Runtime enables you to run executables or use DLLs created with LabWindows/CVI on a machine without the development environment installed. It is backwards compatible and may be used with applications that were created with previous versions of LabWindows/CVI. You can distribute the Runtime according to your license agreement. The mark LabWindows is used under a license from Microsoft Corporation. Windows is a registered trademark of Microsoft Corporation in the United States and other countries.
ni-max-remote-provider 20.0.0.49152-0+f0 windows_all Provides remote configuration of NI Real-Time targets in Measurement & Automation Explorer (MAX).
ni-ceip-x86 4.1.1.49152-0+f0 windows_all NI Customer Experience Improvement Program (32-bit) gives NI customers the ability to contribute to the design and development of NI products.
ni-daqmx-runtime-core 20.0.0.49152-0+f0 windows_all Run-time components required to deploy applications using National Instruments data acquisition devices.
ni-wif 20.0.0.49152-0+f0 windows_all Use NI Web-Based Configuration and Monitoring to configure and control the Application Web Server as well as remote devices, like an RT target.
ni-max 20.0.0.49152-0+f0 windows_all Use this application to configure, test, and communicate with your NI hardware. Use Measurement & Automation Explorer (MAX) to configure, test, and communicate with your National Instruments hardware. You must install the appropriate driver software for your hardware to appear in MAX.
ni-vipm-helper 20.0.1.49152-0+f0 windows_all Discover and install LabVIEW add-ons from the LabVIEW Tools Network. Package your own reusable code and share it with others.
ni-daqmx-20.0.0-dotnet-fx45-runtime 20.0.0.49152-0+f0 windows_all Provides .NET Framework 4.5 runtime support for applications that use the NI-DAQmx .NET API
ni-daqmx-20.0.0-dotnet-fx40-runtime 20.0.0.49152-0+f0 windows_all Provides .NET Framework 4.0 runtime support for applications that use the NI-DAQmx .NET API
ni-assistant-framework-x86 20.0.0.49152-0+f0 windows_all NI Assistant Framework (32-bit) is a toolset for making software applications, with a particular emphasis on tools needed for measurement applications.
ni-rtsi-ui 19.1.0.49152-0+f0 windows_all This is an infrastructure package for NI Software.
ni-pxiplatformservices-provider 20.0.0.49152-0+f0 windows_all Allows PXI system configuration in Measurement & Automation Explorer.
ni-labview-2020-core-x86-en 20.0.2.49152-0+f0 windows_all LabVIEW is systems engineering software for applications that require test, measurement, and control with rapid access to hardware and data insights. The LabVIEW programming environment simplifies hardware integration for engineering applications so that you have a consistent way to acquire data from NI and third-party hardware. LabVIEW reduces the complexity of programming, so you can focus on your unique engineering problem. LabVIEW enables you to immediately visualize results with built-in, drag-and-drop engineering user interface creation and integrated data viewers. To turn your acquired data into real business results, you can develop algorithms for data analysis and advanced control with included math and signal processing IP or reuse your own libraries from a variety of tools. To ensure compatibility with other engineering tools, LabVIEW can interoperate with, and reuse libraries from, other software and open-source languages.
ni-daqmx-config-support-core 20.0.0.49152-0+f0 windows_all Run-time components required to deploy applications using National Instruments data acquisition devices and support for configuring NI hardware via the Measurement & Automation Explorer (MAX).
ni-syscfg-labview-2020-support-x86 20.0.0.49152-0+f0 windows_all Provides libraries, documentation, and examples for using the NI System Configuration API to discover and configure systems and devices within LabVIEW 2020 (32-bit).
ni-daqmx-development-support 20.0.0.49152-0+f0 windows_all This is an infrastructure package for NI Software.
ni-daqmx-labview-2020-support-x86 20.0.0.49152-0+f0 windows_all Provides NI-DAQmx support for LabVIEW 2020 (32-bit)
ni-daqmx-c-support 20.0.0.49152-0+f0 windows_all Provides files to create NI-DAQmx applications using ANSI C compilers like Microsoft Visual C++ 6.
ni-daqmx-dotnet-fx45-support 20.0.0.49152-0+f0 windows_all Provides .NET interface for DAQ devices and adds NI-DAQmx support for .NET Framework 4.5.
ni-daqmx-dotnet-fx40-support 20.0.0.49152-0+f0 windows_all Provides .NET interface for DAQ devices and adds NI-DAQmx support for .NET Framework 4.0.
ni-daqmx 20.0.0.49152-0+f0 windows_all NI-DAQmx provides support for customers using NI data acquisition and signal conditioning devices. NI-DAQmx is an NI instrument driver that controls every aspect of your DAQ system, including signal conditioning, from configuration to programming in LabVIEW to low-level OS and device control. You can build your applications with measurement-specific VIs, functions, data types, and analysis integrations and reliably make faster measurements with optimized DMA data transfer and single-point I/O.
ni-cvi-sql-toolkit-runtime 2.4.0.49152-0+f0 windows_all The LabWindows/CVI SQL Toolkit Runtime
ni-cvi-teststand-debugger-support 19.0.0.49152-0+f0 windows_all Installs the LabWindows/CVI TestStand Debugger Support components.
ni-teststand-14.0.0-runtime-fx20-support 19.0.0.49154-0+f2 windows_all TestStand 14.0 Runtime GAC Assemblies
ni-teststand-14.0.1-runtime-fx20-support 19.0.0.49154-0+f2 windows_all TestStand 14.0.1 Runtime GAC Assemblies
ni-teststand-2016-runtime-fx40-support 19.0.0.49154-0+f2 windows_all TestStand 2016 Runtime GAC Assemblies
ni-teststand-2017-runtime-fx40-support 19.0.0.49154-0+f2 windows_all TestStand 2017 Runtime GAC Assemblies
ni-teststand-2019-licenses 19.0.0.49154-0+f2 windows_all TestStand License files.
ni-teststand-2019-runtime-fx40-support 19.0.2.49155-0+f3 windows_all TestStand 2019 Runtime GAC Assemblies
ni-teststand-3.0.0-runtime-fx11-support 19.0.0.49154-0+f2 windows_all TestStand 3.0 Runtime GAC Assemblies
ni-teststand-3.1.0-runtime-fx11-support 19.0.0.49154-0+f2 windows_all TestStand 3.1 Runtime GAC Assemblies
ni-teststand-3.5.0-runtime-fx11-support 19.0.0.49154-0+f2 windows_all TestStand 3.5 Runtime GAC Assemblies
ni-teststand-4.0.0-runtime-fx20-support 19.0.0.49154-0+f2 windows_all TestStand 4.0 Runtime GAC Assemblies
ni-teststand-4.1.0-runtime-fx20-support 19.0.0.49154-0+f2 windows_all TestStand 4.1 Runtime GAC Assemblies
ni-teststand-4.1.1-runtime-fx20-support 19.0.0.49154-0+f2 windows_all TestStand 4.1.1 Runtime GAC Assemblies
ni-teststand-4.2.0-runtime-fx20-support 19.0.0.49154-0+f2 windows_all TestStand 4.2 Runtime GAC Assemblies
ni-teststand-4.2.1-runtime-fx20-support 19.0.0.49154-0+f2 windows_all TestStand 4.2.1 Runtime GAC Assemblies
ni-teststand-4.5.0-runtime-fx20-support 19.0.0.49154-0+f2 windows_all TestStand 4.5 Runtime GAC Assemblies
ni-teststand-4.5.1-runtime-fx20-support 19.0.0.49154-0+f2 windows_all TestStand 4.5.1 Runtime GAC Assemblies
ni-teststand-5.0.0-runtime-fx20-support 19.0.0.49154-0+f2 windows_all TestStand 5.0 Runtime GAC Assemblies
ni-teststand-5.0.1-runtime-fx20-support 19.0.0.49154-0+f2 windows_all TestStand 5.0.1 Runtime GAC Assemblies
ni-teststand-5.1.0-runtime-fx20-support 19.0.0.49154-0+f2 windows_all TestStand 5.1 Runtime GAC Assemblies
ni-teststand-session-manager 19.0.2.49155-0+f3 windows_all A utility for hardware session management.
ni-teststand-version-selector 19.0.2.49155-0+f3 windows_all A utility to select the active TestStand version.
ni-teststand-2019-ade-support-shared-x86 19.0.2.49155-0+f3 windows_all Source code for user-modifiable components, API, and templates in TestStand.
ni-teststand-example-launcher 19.0.2.49155-0+f3 windows_all A utility used by TestStand Help to launch examples.
ni-mstudio-ui-styles3d-fx40-19.0.0-runtime 19.0.0.49152-0+f0 windows_all Measurement Studio UI Styles3D Library Runtime for .NET Framework 4.0
ni-teststand-2019-file-differ-launcher 19.0.2.49155-0+f3 windows_all A utility for launching the TestStand File Diff and Merge Utility associated with the active version of TestStand.
ni-teststand-2019-runtime-x86 19.0.3.49156-0+f4 windows_all The TestStand Runtime is a software add-on that enables engineers to run TestStand applications on a non-development machine.
ni-mstudio-ui-fx45-19.0.0-runtime 19.0.0.49152-0+f0 windows_all Measurement Studio UI Library Runtime for .NET Framework 4.5
ni-teststand-2019-tools-x86 19.0.3.49156-0+f4 windows_all Tools for use with TestStand to perform development tasks, such as deployment, diff and merge, analysis, and migration.
ni-teststand-2019-ade-support-x86 19.0.2.49155-0+f3 windows_all Source code for user-modifiable components, API, and templates in TestStand.
ni-mstudio-ui-winforms-fx45-19.0.0-runtime 19.0.0.49152-0+f0 windows_all Measurement Studio UI WinForms Library Runtime for .NET Framework 4.5
ni-teststand-2019-user-interfaces-x86 19.0.2.49155-0+f3 windows_all TestStand User Interface executables and source files.
ni-teststand-2019-sequence-editor-x86 19.0.3.49156-0+f4 windows_all Application for developing and debugging TestStand sequence files.
ni-teststand-2019-process-models-source-x86 19.0.2.49155-0+f3 windows_all Source Code for process models and supporting components.
ni-teststand-2019-examples-x86 19.0.2.49155-0+f3 windows_all Examples for use with TestStand.
ni-teststand-2019-documentation-x86 19.0.3.49154-0+f2 windows_all Help and PDF files for TestStand documentation.
ni-teststand-graphcontrol3 19.0.2.49155-0+f3 windows_all Graph control for TestStand reports.
ni-teststand-2019-process-models-runtime-x86 19.0.2.49155-0+f3 windows_all Default model sequence files, result processors, and utilities, also includes legacy sequence files.
ni-teststand-2019-x86 19.0.3.49156-0+f4 windows_all TestStand is application software that helps test and validation engineers quickly build and deploy automated test systems. TestStand is ready-to-run test management software that is designed to help you quickly develop automated test and validation systems. You can use TestStand to develop, execute, and deploy test system software. You can extend the functionality of your system by developing test sequences in TestStand that integrate code modules written in any programming language. TestStand provides extensible plug-ins for reporting, database logging, and connectivity to other enterprise systems. You can deploy test systems to production with easy-to-use operator interfaces.
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
Message 18 of 29
(5,564 Views)
I have an install script for LV2018, several drivers and other component. Sometimes it runs in 2 hours, other times 24 hours. The main factor is if our Anti-Virus Software gets triggered. If it decided to inspect each file as it is copied and installed, it takes forever.
I am experimenting with the LV2020 nipkg.exe installer. It seems to install very quickly on a virtual machine. Maybe 20 minutes.
Hope that helps.
Message 19 of 29
(5,427 Views)
Maybe that's why all installers, LabVIEW included, always recommend disabling antivirus software before installing.
Bill
CLD
(Mid-Level minion.)
Message 20 of 29
(5,397 Views)
