Why does Print Window print hidden subdiagrams?
Why does Print Window print hidden subdiagrams?  "Help" says: Print Window displays a dialog box you can use to print the front panel or block diagram. Select the menu item on the front panel to print the front panel. Select the menu item on the block diagram to print the block diagram. Selecting this menu item prints the entire front panel or block diagram but does not print hidden subdiagrams in Case, Event, or Stacked Sequence structures.
(2,563 Views)
Well, it does not print hidden subdigrams for me. Maybe you confused "Print Window" with "Print ..." where it will print hidden subdiagrams by default for the diagram window?
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(2,545 Views)
