Why does Start Digital Edge in Start Trigger.vi do a kind of timeout?
Hi I am doing a manual trigger on my hardwareboard by inserting a 5 volt source into the selected triggerchannel a couple of seconds after I push the start button.
The generation never starts. But if I put the trigger signalchannel  equal to the external sampling clock the appended vi work.
Example I use PFI7 as trigger source which is also the source of the sampling clock.
Could somebody explain?
Kindest regards,
Lasse
(3,083 Views)
Accepted by topic author laskar01
One cannot just insert a wire with a 5 V potential to PFI6 for instance if PFI6 is used as a trigger for "Start Digital Edge" daqmx -vi. The pin is floating and just inserting 5V does not guarantee a low to high edge.
If I use a potentiometer to pull the channel low first, and then increse the voltage, the trigging happens.
(3,058 Views)
