Why does a LabVIEW executable generate two taskbar buttons on the taskbar?
When a LabVIEW executable is run, it generate two taskbar buttons (with the same name) in the task bar each of them pointing to the same window (panel). Is there a way to prevent it from creating two buttons?
thanks
~Vipin
(5,335 Views)
I believe the technical reason is so that you will still have access to your windows even if you make all your VI windows completely disappear.
To get rid of it, place the line HideRootWindow=TRUE in the ini file of your app (it's created the first time you run it).
___________________
Try to take over the world!
(5,319 Views)
Add the following line to your executable's .ini file
HideRootWindow=True
There's a KnowledgeBase item here [link removed; article no longer available].
Fading out. " ... J. Arthur Rank on gong."
(5,318 Views)
Thanks. That fixed it.
~Vipin
(5,308 Views)
I was going to post a thread but I did a search and found this thread. Thanks for asking and thanks for the answers.
(5,186 Views)
... kudos to You for searching first. Smiley Wink
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
(5,174 Views)
