Why does a call to the nifgen.dll function "nifgen init" cause the pc to crash?
Hello, I am using Labview 5.1.1 and trying to call the NıFgen_32.dll function "nifgen inıt". However, when i make thıs call to the dll, the pc locks up. By locks up, I mean the monitor goes black and keyboard no longer works. You must press the reset button to reboot. I am using the NI 5431 arb card. We are doing the same thing on another pc, and it appears to work fine. I suspect it is a memory issue, but having trouble locating it. We are also using the nifgen.llb file. (I believe that is a labview library file created by ni.) We are using NiFgen version 1.0.
(2,511 Views)
Does the board work in Measurement and Automation Explorer?
Have you tried upgrading the driver to NI-FGEN 1.5.1? This includes a Soft Front Panel that helps to trouble shoot the boards, and exposes the majority of the functionality of the function generator.
If you upgrade NI-FGEN you will also need to uppgrade NI-DAQ, IVI engine, NI-VISA. All of this is explained on the download page of NI-FGEN.
Drivers and Updates: NI-FGEN
Hopfully this helps.
(2,511 Views)
