Why does a digital indicator formatted for time & date add 16 hours to the input?
I wire a digital indicator with a double precision value that is supposed to indicate an elapsed time. But the indicator (formatted for time and date, with the date inactive) always adds 16 hours to the wired input.
This problem occurs even in a simple vi I wrote that only consists only of a constant wired to the indicator.
Using LabView 6.0.2
(2,699 Views)
Labview interprets the number passed into an indicator formatted for date & time as seconds since Jan. 1st 1904. I'm assuming that since you're looking for elapsed time this is not what you're passing in. One thing that I've done is get the elapsed time in seconds and write a routine to convert that into whatever format you want.
(2,699 Views)
Right.
And the base time is 16h00, 01 Jan 1904, hence always displaying the extra 16 hours. I can't believe I overlooked that.
Mike
M. J. Eggertson
Department of Chemistry
University of Washington
(2,699 Views)
