Why does my program not run when it is generated as an application
Why can't my program run after it is generated into APP? Error code: 7, the file path I have determined is correct.
Message 1 of 8
(1,919 Views)
And what would that correctly determined path be in your case? We can't debug pictures so you either have to attach your entire project (as ZIP file) or write at least a few dozen pages of prosa describing what you did if you feel your project files are to secret to post. 😀
Rolf Kalbermatter  My Blog
Message 2 of 8
(1,890 Views)
This is the VI.
Here is my specific configuration.
Message 3 of 8
(1,860 Views)
I don't think that VI is supported in run-time engine!
Lucian
CLA
Message 4 of 8
(1,848 Views)
Do you mean that this VI does not support running as an application?
I didn't find any specific details about VI.
Message 5 of 8
(1,845 Views)
Usually it says in the help dialogue if VI is not supported in runtime, but this one doesn't say anything.
Message 6 of 8
(1,839 Views)
It is specified only for Build.vi but I think none of the VIs from Application Builder palette can be called in run-time engine. It makes sense since build operations are specific to IDE.
Lucian
CLA
Message 7 of 8
(1,837 Views)
The vi uses scripting methods to manipulate project properties.   No, it can't run in the RTE since scripting is not supported.
Message 8 of 8
(1,804 Views)
