Why does my version 6.1 vi crash with labview 7.1
I originally wrote my vi with Labview 6.1. Now I need to work on it some more but using Labview 7.1. It crashes at a "Insert into Array" vi. I am sure there will be other problems. Are there any known issues and reccommendations out there? I also have to compile it.
(2,392 Views)
Crashes how? Do you get an error message, does the program run for a while and then stop or what? I'm not aware of any issues with converting 6.1 to 7.1 and the insert into array. Can you post an example that demonstrates the behavior you are seeing?
(2,379 Views)
