Why does the DB Tools List Columns.vi only report -1 for the defined column size?
I am using LabVIEW 8.2.1 with the database connectivity toolset with an SQL Server 2000 database. I would like to see how large a full record could be, so I used the DB Tools List Columns.vi in the database toolset. It easilly displays the column name and the column type, but only returns a -1 for the defined size. Of course when I add up the defined size elements, it gives me -351, which is the number of columns in that particular table. The vi I am using is very simple. I open a database connection, retrieve the data, and close the connection. The retrieved data is an array of clusters. I index it by running it through a for loop, and unbundeling each of the three parameters, and reforming arrays at the end of the for loop. This is as about the simplest vi I have ever made, but only part of it works.
(3,041 Views)
SciManStev-
          I don't know if this gets you the functionality you want because I don't have access to your file, but I would have code it this way (see attached picture). I would have used a Array to Cluster.vi to convert the column info ouput array into a cluster so I could use Unbundle by name. I think this is what you are wanting because from what I see, you only access the file once everytime the VI runs (right?). Try this and let us  know how it works out. Thanks!!
(3,021 Views)
This did not work. It gave me 351 separate clusters that each had to be selected for the defined size. Even with this rediculously sized cluster, every result was still -1. The first code should have worked. It worked fine with the column names and column type, but always gave me a -1 with the defined size. I manually added up the defined size in about 30 minutes, and got 4432. The maximum size allowed in any SQL Server 2000 record is 8060 bytes, so I was within my limits. I had wanted to test the other 45 tables in my database, quickly rather that add up the sizes individually, which would take eons. I think that either this function will not work with SQL Server 2000, or it is a true bug. Thank you for your responce.
(3,017 Views)
SciManStev-
           The bug part of your answer got me thinking and I checked this behavior against our CAR (corrective action request) database and found that in fact it was a bug originaly reported in 2003, found again in 2007, and now finally fixed with the release of Database Connectivity Toolkit 1.0.2 in June of 2008. So it is actually a known bug but unfortunately there was no known workaround added for older versions. I hope this helps some more. Cheers!!
(3,012 Views)
Thank you so much! I will be trying to upgrade my 8.2.1 version of LabVIEW to 8.6 in the next few weeks. The last time I tried to upgrade to the first version of 8.5, I had all kinds of errors in my database communication, so I had to pull it out and reinstall 8.2.1. As soon as I get the time I will try again, only this time to the latest version, and hopefully this problem win't be there. Thank you very much for your time.
(3,010 Views)
