Why does the Font color change on my front panel?
I'm using the Font Dialogue to change the color of highlighted text on my front panel. After I save and reopen my app some of the Text will revert back to their original color (Black). Is this a bug in or am I missing something?
(2,831 Views)
I assume that with "app" you mean the VI, not a built executable. Can you attach a VI that shows the problem? What is your version?
(2,826 Views)
I am using Labview 2012. I can attach my complete Labview Program, but it's 300K with 9 sub vis. I've attached just the main Labview program where I'm having the problem, but can include the subvis if necessary. You can see the problem on the front panel.
(2,817 Views)
I assume that you want all control labels with white text. If I change the black ones to white and save the VI, the white text color is retained.
(2,811 Views)
That's true. I have changed all the text to white and saved the program. The front panel you see was saved with all the text in white. Some of the text went back to black when I reopened the program. I guess I can live with it and just change my front panel color to something that makes black text more visible. Maybe there's a bug. Anyway, thanks for your help.
(2,807 Views)
