Why does the Skale option in a Subpanel object doesn't work Propperly?
I have testet the SubPanel Object in a Vi. But the option Skale Frontpanel doesn't work propperly with the Vi that is called from the Subpanel element.
(Have a look at the attached Word-File with the Print-Screens)
The lines from the original Vi are warped in the Subpanel object, when I use the option Skale Frontpanel.
I use Windows XP and LabVIEW 7 Developper Suite Professional Cotrol Edition.
Thank you verry much for your help!
(2,526 Views)
Unfortunately the line decorations are known not scale properly with the other front panel objects. One possible workaround is to use a �Flat Box� decoration and make it into a very thin box. This box can then be filled with a black color using the set color tool from the tool palette. This technique can be use to create horizontal and vertical lines.
Hope this helps! Let me know if I can help with or clarify anything.
Ken S.
(2,526 Views)
