Why does the invoke node give an error when in an executable?
I have an invoke node being used to deploy a shared variable library being used in my executable. When running in the development environment the node runs fine. When in the runtime environment I always get an error code 1 from the invoke node. This code states: Error 1 occurred at Invoke Node in Deploy_SVLIB.vi
Possible reason(s):
LabVIEW:  An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
I do not have any invalid characters. It is the same path as in the development environment. Any ideas out there? I took the part of the VI that is giving me the error and attached it.
Troy
(2,931 Views)
Try wiring a constant to the Target IP address with localhost in it and see if that works for you.
Kenny
(2,903 Views)
Kenny - This did not fix my problem however I did find out what my problem was. After thinking about this for a while I checked my installer and did not have the shared variable engine selected to be included. After I fixed this and rebuilt my installer the shared variable library launches fine. Thanks for your response.
Troy
(2,881 Views)
