Why don't MySQL math expresions work with the Database toolkit?
If you use the database toolkit to execute:
Select 1+1;
on a MySQL database (conecting through MyODBC), the recordset returned has no data and geting it's column properties cause a Warning (Type not supported) to be thrown by the Database Conectivity Toolkit.
(2,814 Views)
Each database has some special commands that it uses. I suspect select is not a standard odbc command and won't work with the database connectivity toolkit.
Jeremy
(2,814 Views)
I figured it out.
Select Round(1+1);
this will force MySQL to convert the 'expresion' data type (or whatever it was trying to return) to an integer which the Database toolkit understands.
(2,814 Views)
