Why is 3dgraph loading as an empty container?
I am running LabVIEW 6.1 on a Dell Dimension 8100 under Windows 2000. With a clean install of LabVIEW, I can use 3dgraph feature with no problem until I do a cold reboot of the computer and reload my LabVIEW VI - the 3dgraph shows up as an empty container. When this happens, the 3dgraphs in the example VIs are also loaded as empty containers. To re-enable use of the 3dgraph, I can do a software repair procedure with the LabVIEW disks. However, this is not a permanent fix, since the 3dgraphs become empty containers after subsequent cold reboots. This does not appear to be caused by video card problems - I've installed the latest Dell driver. This does not seem to be an activex problem - I have had no problems loading th
e CW 3dgraph into Microsoft Excel. Also, the *.ocx file is in the proper (windows/system) directory. I suspect there's something causing a corruption or memory leak in LabVIEW's interaction with the CW 3dgraph feature. I'd like to solve this problem because this feature would be very useful to me and I don't want to have to do a software repair every time I start up my computer.
(3,146 Views)
Gary,
I would try to unregister the cw3dgrph.ocx file:
Go to Start > Run,
and type "regsvr32 /u "
And register it again:
"regsvr32 "
In both cases, you will get a dialog box prompting you that your control has been unregistered or registered successfully respectively.
Hope that will help,
Cyril Bouton
Applications Engineering
Cyril Bouton
Active LabVIEW Developper
(3,146 Views)
Cyril,
Unfortunately, this doesn't seem to solve the problem. I unregistered and re-registered the .ocx file after encountering a blank container; this did not bring the 3dgraph back (within NI examples or my own VIs). Then I tried a software repair of LabVIEW 6.1 and unregistering/re-registering; this did not prevent the disappearance of the 3dgraphs once a cold re-boot was executed.
(3,146 Views)
