Why is LabView Run Time generating an ApplicationName.ini � file after closing the application?
I have build an application using LabView 6.0i, when his program shuts down
(using the Exit function), It seems that LabView Run Time Engine generates
a file called just like the program name but with the extension �.ini�.
Unfortunately, this new file effects on my program.
So my temporally solution, is to delete this *.ini file before the application
starts up.
Message 1 of 1
(2,924 Views)
