Why is my Application Slow ?
I am using LabView 6.0.2 on both the Test Machine (Win N/T 4.0) and a Notebook Computer Win 2000). I am creating and running a Diagram-less .LLB file on the Test Machine. If I edit the the VI with the main Panel on my Notebook computer and then copy that VI back to the Test Machine, it runs slowly (hangs for 1/2 second on display update in main loop). If I edit the VI ONLY on the Tester then it executes the .LLB very quickly. The Tester is 1024 x 768 & 256 Colors. The Notebook is 1280 x 1024 & 65,000 Colors. Should that even matter ? I copied all files to the notebook, modified MainProcess.VI and copied just that file back to the Test machine and created the Diagram-less LLB. I have to use a back-up file to fix problem because
editing MainProcess.VI on the Test Machine will not make it fast again. What could be corrupted by editting one file on my Notebook computer ? All other features of the Tester work perfectly except slower speed.
Message 1 of 8
(3,457 Views)
If you are under windows, then you should put a small wait inside every loop so that the app doesen't hog your processor time. If this doesen't work, try updating your graphic card drivers.
Hope this helps
Message 2 of 8
(3,457 Views)
I have a wait in every loop. I have the latest video drivers. NOTE: The program works just fine UNTIL I modify the MainProcess.vi on a my Notebook Computer and then copy that one VI back to the original computer. What can be changed in a .VI, just by editing the .VI on another computer, that would would make it run slow when returned to the original computer. The change can be as trival change as clearing a Local for a Control a second time, for example. The original .VIs run just fine and can only be editted only on that computer. Same LabView 6.0.2 different O/S's WIN N/T (tester) vs Win 2000 (notebook).
Message 3 of 8
(3,457 Views)
Do both computers have the same Labview property settings for properties such as Multi-threading and VI/Sub VI priorities? Check each one's properties under File>VI Properties> Execution and then Performance and Disk categories.
Good Luck, Doug
Message 4 of 8
(3,457 Views)
Doug,
I checked the Tools->Options settings for LabView. Two minor differences. I had "Show Connector Dots" ON and "Allow Terminal to be Deleted from Diagram" ON, all other options are identical. I turned off the differences but still when I edit and copy the .VI's back to the Tester it runs 5X slower. All I have to do to "break" the .VI is MOVE something on the Panel and save. I made all kinds of changes ON THE TESTER to the .vi's last week, still running fast. If I ship the tester I will never be able to edit from my Desk. Also, running the .vi's is slow, I don't have to make the Diagram-less .LLB to see the slowness.
I have checked a few of the .vi's Properties (there are 120 .vi's). They are identical so far. All are normal except the main.vi is "Auto-R
un when Loaded".
This program was originally designed under 5.x by an outside contractor, then converted to 6.0 and modified for our tester.Don't know if that matter.s
Thanks for your ideas.
Message 5 of 8
(3,457 Views)
It sounds like all should work, but...
Time to see if the NI gurus have a theory - Email or call them directly, they may have a cure. If I think of other ideas, I'll reply. Good Luck, Doug
Message 6 of 8
(3,457 Views)
Doug,
Just for the fun of it, I replaced the 1 Meg ISA Video Card with a 4 Meg PCI Video card in the Tester. I Loaded the new drivers. I can now edit the .VI's at my Desk, copy them back to the Tester and have the Tester run FAST!!!! The Electrical Engineer had installed a 1 Meg ISA Video Card becuase we have successfully used this card on previous LabView 5.x Testers. We called SIIG and we do have the most recent Driver for the 1 Meg Video Card. Evidently there is some weird quirk. LabView says it supports anything that Win N/T supports, well not quite in this case
Thanks for your help.
Message 7 of 8
(3,457 Views)
Great...
Message 8 of 8
(3,457 Views)
