Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Why is my CLUSTER showing only three numbers after the point
germannubie
Member
02-12-2004
06:28 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I want to save the results of my Project in .doc
I did this with the "array-to-Cluster" Order
0
Kudos
Message
1
of 2
(2,428 Views)
Reply
Re: Why is my CLUSTER showing only three numbers after the point
Joe_Guo
Active Participant
02-12-2004
08:05 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
you can right click on the "array to cluster" node and select size or # of element, type in the same number as your cluster elements.
Joe
0
Kudos
Message
2
of 2
(2,428 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
