Why is my code so dog slow?
@Defaphe wrote:
Try with less samples and a smaller timebase, it should update quicker ( but then if you have a signal processing to do you will have less time to operate before the next batch of data is coming).
In a "streaming" situation such as you describe, the "signal processing" should be done in the "Consumer loop" using the "free time" available while the Producer is gathering the Picoscope samples.
Bob Schor
Message 11 of 11
(256 Views)
