Why is my variable incrementing multiple times?
In my application I need to increment a variable when a certain condition is met so I have a case statement which checks whether the condition is true then increments a variable. However the variable is increment for the entire time that the condition is met. How can I restrict this to only increment one time per occasion of the condition being true. I've tried while and for loops that execute only one time and nothing seems to work.
(3,677 Views)
A simple way to do this is using a boolean variable that is set to true by your condition and then set to false inside the case where the variable is incremented.
Check attached vi.
Hope this helps,
Paulo
(3,670 Views)
here is another way of doing it.
-Joe
(3,666 Views)
I have modified Paulo's example so that you don't use local variables. This should be a more efficient approach since the local variables will make copies of the boolean.
(3,655 Views)
Or you could do it similar to this.
Joe.
"NOTHING IS EVER EASY"
(3,641 Views)
Oops. I just realized that the vi was not attached. Here it is.
(3,638 Views)
This is how i'd go about it
(3,619 Views)
