Why is "debug_dll.txt" Automatically Being Created?
I'm losing my mind a bit and searching is failing me because of how internet search engines work.  So I have an application that listens over a TCP request.  The request will specify a path to a DLL it needs to run.  It will then run the DLL, and send back over TCP the results.  It is on a platform where the DLL is not compatible so this is a work around.
This all works fine in development.  I build an EXE, and it too runs as expected.  But one odd thing I noticed, is that after it runs the DLL and sends the reply over TCP, a new text file named debug_dll.txt is created next to the EXE.  In it appears to be the parameters being sent to the DLL, and the response coming back.  I looked at the code and I'm not explicitly doing this in the G code.  I added a disabled diagram structure around the Call Library function, built the new EXE, and now the text file isn't created, because the DLL isn't being ran.
I don't remember seeing this type of automatic DLL debugging built into the application before.  Is there some place I can turn this off?  The EXE will eventually be running from the Program Files folder where I probably don't have write permissions anyway but I just don't remember seeing this type of behavior, or where I could have accidentally set it.  Thanks.  LabVIEW 2020 32-bit, Window 10 x64.
(444 Views)
Accepted by topic author Hooovahh
Just to rule out the obvious, are you sure that the DLL isn't creating this file?
(434 Views)
Oh for Pete's sake. I've ran this DLL so many times I just assumed this wasn't it...turns out it is and it has always been ran from a location that didn't have write permissions so nothing happened. I ran it from the build directory and saw this.
(427 Views)
