Why is the array in the complex waveform output of MT Modulate FSK missing 255 elements?
Hi!
I'm new so I appreciate any help 🙂
I am running this FSK example in LabVIEW (VI is attached). As it can be seen in the block diagram, the specified number of samples per symbol is 512. If I am running 2-FSK, I have 1 bit per symbol. So if I have 128 bits, I have 128 symbols. and if I have 512 samples per symbol, I am expecting 65536 samples/elements in the output complex waveform of MT Modulate FSK. However, I only get 65281 elements in the array. There are 255 missing elements.
If I run 4-FSK and have 128 bits or 64 symbols, I expect 32768 in the array. But then again, I am short of 255 elements and get 32513.
Am I missing out on something? Have I misunderstood something? Thank you so much for your help.
(2,918 Views)
Hi, it looks like you are dealing with a High Speed product. For this reason I would recommend posting this question on the High Speed forum instead of the LabVIEW forum.  You can find the High Speed forum here: http://forums.ni.com/t5/High-Speed-Digitizers/bd-p/150
(2,867 Views)
Thank you so much for your reply. Will post my question on that forum. Thank you again!
(2,857 Views)
(2,856 Views)
