Why is the start-up time 5 minutes for Version 8?
We installed LabVIEW 8 on 2 new PCs with Windows XP. On both machines the program needs 4 to 5 minutes to start. This is not acceptable.
Message 1 of 27
(7,025 Views)
For comparison. On my PC (2.4GHz XP SP2) it takes about 50 sec. to startup LV8. LV7 starts-up in 10 sec.
Message 2 of 27
(6,999 Views)
Hello KC,
thanks for the quick reply.
We have Pentium 4 CPU 3.4 GHz XP SP1 RAM 1024MB.
Regards from Winni
Message 3 of 27
(6,975 Views)
I have the same problem with long startup time.
PC1 65sek PIII 1.2Ghz 512MB RAM
PC2 55sek 1.7Ghz Pentium M 1GB RAM
PC3 55sek 1.7Ghz Pentium M 1GB RAM
And as you say Winni..... it is not acceptable.....
Message 4 of 27
(6,967 Views)
I do not know why it is taking so long. on my machine (P4 3.2ghz 1GB ram) it takes about 30 - 40 seconds.
Joe.
"NOTHING IS EVER EASY"
Message 5 of 27
(6,955 Views)
LV8 10 - 11 seconds. LV7.1 8 - 9 seconds. Dual G5 2.3 GHz 1GB RAM, Mac OS X 10.4.3.
Lynn
Message 6 of 27
(6,917 Views)
Thanks for all replies,
I talked to NI and they do not have an explanation yet. Here is a more precise information:
After program start it takes up to 3 minutes before the yellow start window appears which states
"LabVIEW 8 - Base development system".
After a total time of about 5 minutes the program finally starts with the browser window.
1st PC used is:
Hardware:
HP Workstation xw4200 with Intel Pentium 4 CPU 3.40 GHz 1024 MB RAM
Software:
Windows XP SP1 Revision 5.1.2600
2nd PC used is:
Hardware:
Dell Precision Workstation 670 with Xeon™ CPU 3.40 GHz 1024 MB RAM
Software:
Best regards from Winni
Message 7 of 27
(6,912 Views)
Why are your new PC's only at XP SP1? SP2 has been out for quite a while now.
Have you looked at task manager to see what applications are using CPU during LV loading, in addition to memory usage.
Message 8 of 27
(6,881 Views)
Mine takes well under 10 seconds.
winni,
  • how is the speed the next time you start it (usually it takes a bit longer after a fresh reboot).
  • Is you installation local or on a network resource?
  • Is this a plain default install or did you add things to the palette?
  • what kind of hardware, DAQ drivers, etc. are installed?
  • What antivirus are you running? Have you tried if disabling it temporarily makes a difference?
  • What else is running on these PCs. Is it guaranteed virus-free?
  • Is the antivirus up-to-date?
  • Could it be you have spyware bloat?
  • I would recommend a scan with the free htMicrosoft AntiSpyware beta.
  • Is your HD nearly full and heavily defragmented?
  • Does you HD contain errors? Run scandisk with a full surface scan.
  • Are there any problems in the windows device manager? (e.g. do the HDs run in compatibility mode).
Message 9 of 27
(6,874 Views)
Hi all
Just for comparison: in my "poor man" PC - PIII 700 Mhz. 320 M ram running XP Pro SP2- after a fresh reboot, it takes about 2 minutes to start. Afterwards, it takes about 50 s. to restart in same session.
Antivirus anti-spyware and proxy are on.
cheers
Alipio
"Qod natura non dat, Salmantica non praestat"
Message 10 of 27
(6,836 Views)
